downsizingnow48
Elite Member
I use a Wilson directional antenna and amplifier to pick up a Verizon cell phone signal. It works pretty well. Without the antenna and amp, I have zero signal at ground level (ranging from "no service" to -110 db). With it, I get -80 to -90 db according to the iPhone internal signal strength meter. We use a USB727 modem plugged into a wireless router for internet.
I oriented the antenna using the OpenSignal cell phone app, which shows you an arrow that points in the direction the signal is coming from.
We recently had very heavy winds that rotated the antenna about 35 degrees from where I had it aimed. The signal is noticeably improved.
What I want to do now is get a real signal strength meter, that plugs into the coax from the antenna, and then rotate the antenna while checking the signal strength. I figure this will be a more accurate way to orient the antenna than the cell phone app.
I found a signal strength meter but it costs $330:
Amazon.com: WilsonPro 46 118 RF Cellular Signal Meter: Cell Phones & Accessories
So this is my question. Is there a generic and cheap signal strength meter I can use instead of the Wilson meter? I don't know enough about radio frequency electronics to figure this out on my own.
Thanks for any help!
