CCM Toplink hose is nicked
   / CCM Toplink hose is nicked #1
mscheer772
Hayward Wisconsin
4310 JD 2003
My CCm toplink got nicked when it was fully retracted. It nicked a metal support I had welded to hold a toolbox. It is not leaking.
Should I replace the hose? Is there any safety issues I should be concerned with, if I do not fix it right away? HELP!!!!!!!!!!
-Mike-
   / CCM Toplink hose is nicked #2
Can you post a picture of the nick? I have some nicked hoses but I didn't think they were bad enough to be of concern. But then again I have no real expertise in the matter.
   / CCM Toplink hose is nicked #4
If it's just the outer fabric jacket that is nicked, then it shouldn't be a problem. If the stainless steel braid is exposed, then tape it up with some good friction tape followed by electrical tape. If the stainless steel braid is damaged you best replace it before it blows out under pressure.
Get a digital camera. I've seen 'em as cheap as $25 now days. You will find a million uses for it, including getting help with problems. As they say, a picture is worth a thousand words!!
   / CCM Toplink hose is nicked #5
Should be no problem. The outer layer is not what is holding in the pressure.
jb
   / CCM Toplink hose is nicked #6
I agree, should be no major concern. I actually bent an adapter fitting going into the cylinder pretty good but it was not cracked. I've used it that way for over 2 years with no leaks, but I did change it earlier this Summer. My hoses have nicks and scratches on them too, but I don't see a problem with a nick in it. On the other hand, there is no substitute for brand new stuff, but then those hoses are pretty rugged and stand up to a lot of abuse.
   / CCM Toplink hose is nicked #7
If there are no broken wires in the high strength steel wire braid and the hose cross section was not crushed, you are totaly ok. If wire was broken and its a 2 layer braid reinforced hose you are still ok if its only a few strands. Just tape over it. If its a single braid hose with broken strands, or any hose that was crushed, I would replace it.
larry
Thanks for all your comments. I'll let the nick go for now. It appears to only encompass the rubber and not the steel bands.
I'm 23 miles from town so add $50.00 in gas to that digital camera. Besides I'm a tecno-phobic when it comes to cameras.
Thanks,
-Mike-
   / CCM Toplink hose is nicked #9
Holy smoke! You use $50 of gas to drive 46 miles? What are you driving and who is getting rich selling you gasoline?;) :D
I'm glad to hear that your damage is only cosmetic. The rubber on the outside of the hose is really protection for things rubbing against the hose braid and from things that might damage the braid. CCM sells quality two-braid hoses so failure should not be expected, but if the rubber is cut, taping it will prevent additional deterioration due to moisture getting under the rubber.
   / CCM Toplink hose is nicked #10
I wouldn't be worrying about the nick, I would be more concerned about the leak in your gas tank.....:) If gas is $4.00 a gallon / $50 = 12.5 gallons 46 miles /12.5 gallons = 3.68 MPG, that's pretty serious. :)
2021 Fleco DX140 24in Tooth Bucket Excavator Attachment (A52377)
2021 Fleco DX140...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
2020 JOHN DEERE CP690 LOT NUMBER 204 (A53084)
2020 JOHN DEERE...
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
2012 International 4300 Reefer Truck (A53472)
2012 International...
2015 Dodge 5500 4X4 Bucket Truck (A53472)
2015 Dodge 5500...
