Snow Equipment Owning/Operating cccoldd weather staaaaarrting
   / cccoldd weather staaaaarrting #1
TugHillDog
Bronze Member
btwn Canada and the Adirondack Mtns
Mahindra 2645 Cab
Anybody out there have any experience with magnetic block heaters for their tractor?
So far my MF1529 has started, but I'd like to make it a little easier on all of us to get it going. I could do the standard antifreeze/coolant insert heater, but saw this magnetic thing advertised on Norther Tool website and thought I'd pose the question here.
   / cccoldd weather staaaaarrting #2
I keep a few magnetic ones on hand just in case my block heater quits. They actually work quite well. 1999 - 200X VW TDI engines just had a flexible rubber pad glued to the oil pan for an engine heater. They also worked quite well.
   / cccoldd weather staaaaarrting #3
I have two of the magnetic ones I used to use on the Farmall C. They work pretty good. DO NOT touch the magnetic side after having them on for a while. You WILL get burned.
   / cccoldd weather staaaaarrting #4
Portable space heater placed under the hood with a heavy blanket draped over the hood will get you through the cold snap. The heater should have a thermostat on it obviously.
Thanks for the notes.
Weatherman predicts 3-5 ft of snow today, so before it comes, i just might get one of those heaters.
Tim- I could share my blanket with my Massey...that would be cool! Thanks for that suggestion.
   / cccoldd weather staaaaarrting #6
Frost plug style heaters are more effective than magnetic heaters but in a pinch anything is better than nothing. If it is sitting outside in the wind covering them will help tremendously on keeping the heat in the engine.
   / cccoldd weather staaaaarrting #7
I know what you are trying to do. But is it wise to have a "arcing and sparking device" under the hood of a vehicle where there may be potential for fire? Just a thought.
   / cccoldd weather staaaaarrting #8
If it was safe enough for our planes and helicopters, I'm pretty confident about our tractors.
   / cccoldd weather staaaaarrting #9
I went to start the Tractor yesterday after 2-3 weeks -25/-40 below wind chills and was turning over slowly I took the torpedo heater pointed at the oil pan for 5 minutes,it started like it was summer time.
   / cccoldd weather staaaaarrting #10
It is SO, SO, much easier than a block heater to use a space heater as the heat made by a magnetic heater dissipates quickly and is of little use.
Even uncovered your mule will wake up after 20 minutes of heating with a torpedo heater .
Just decide where you want to point it and be sure its at least six feet away and turn on the switch.
I use my small generator some times because of the electrical interference it creates in the house circuits.
I use mine to heat the tractor and the truck both as it cheap insurance used to warm the oil
in the crankcase pan
Don't buy a propane one unless you can keep it it indoors to stay warm as they are finicky about being left out of doors/cold garages.
Even with a full tank of propane it did not work well unless it was left in a warm place over night-I brought it back to the retailer and bought the kerosene unit.
I can leave the kerosene unit out of doors to cool or overnight with no issues.
I can use five different fuels JP1,2,3 diesel and kerosene.
Its larger and heats everything up faster.
2017 John Deere HPX615E Gator Utility Cart (A51691)
2017 John Deere...
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
MASSEY FERGUSON 492 TRACTOR (A51406)
MASSEY FERGUSON...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
