CC tie rod issue
   / CC tie rod issue #1
RatherBeJeeping
Norman, OK
Cub 7254
I've got a 7254 that gets pretty well used around my place, and twice I've broken the OE tie rod on the front end. Both times I was digging out a dirt berm with the FEL (tooth bar welded on for better digging) and while backing up a tire drops in to a low spot and the tractor pitches over to the left.
The first time the tie rod broken right away, right where the rod necks down to the threaded section just inboard of the tie rod end. After waiting for another stock piece to come in the piece broke in the exact same place, doing the exact same job.
Now I'm farming this out to a custom motorcycle builder that I know. The rod will be chromoly steel with heim joints on it. I'll drill out the taper on the knuckles to run some grade 8 bolts instead.
2017 MAHINDRA MAX26XL TRACTOR (A51243)
2017 MAHINDRA...
UNUSED AGT INDUSTRIAL SDA-140T LOADER (A51243)
UNUSED AGT...
2015 KIA Cadenza (A50324)
2015 KIA Cadenza...
2014 Ram 1500 Crew Cab Pickup Truck (A50323)
2014 Ram 1500 Crew...
CASE TR270B SKID STEER (A51242)
CASE TR270B SKID...
10' Poly Feed Trough (A50515)
10' Poly Feed...
