CC 3165 - lights stopped working
   / CC 3165 - lights stopped working #1
gary_g5
I've had a CC 3165 for 4 years now. I just noticed that after being store all winter, the headlights and taillights don't work anymore. I checked the fuses in the fuseblock under the hood, but they're all fine. Could it be a blown bulb or broken wire somewhere that's causing them all to stop working? Anybody know where I can get a wiring diagram for the 3165? Thanks.
   / CC 3165 - lights stopped working #2
See if the wires are simply disconnected at bulb housing. There also should be a connection somewhere under the hood. Then check bulbs.
Does that model have to have the key at a notch back for the lights to work?
I've checked all the bulbs and wiring, and nothing is loose or blown. All the wire connections on the back of the dash are secure. To operate the lights, the key is turned to the position between off and run. Like, once you start it up and let it run, you can back the key off a notch and the lights will come on. Well, they used to anyway.
   / CC 3165 - lights stopped working #4
"stored all winter"... best dblechk for mice. they love wiring insulation.
OTW, probably time to chk that ignition switch itself - could be the culprit preventing any power getting to your lights...
   / CC 3165 - lights stopped working #5
I'd bet ignition switch.
   / CC 3165 - lights stopped working #6
A test light will help you track the problem quickly. Check your grounds as well!
Guard Rail Pieces (A51692)
Guard Rail Pieces...
1998 National RV Tropi-Cal T/A 35FT Class A Motorhome (A51694)
1998 National RV...
CASE 621G (A53843)
CASE 621G (A53843)
2003 Paris Utility Trailer (A52377)
2003 Paris Utility...
2008 Ford Escape XLT SUV (A51694)
2008 Ford Escape...
