CC 1517 Battery Light
   / CC 1517 Battery Light #1
McCandless
I recently replaced my CC 1517's battery with a Diehard, but noticed that the battery light is lit while the engine is running; then last night the tractor wouldn't start, so I jumped it. The battery light remained on. I suspect the engine is not charging the battery. This has the Kohler engine in it.
So, how can I determine what the problem is? I'm hoping it's the voltage regulator since its external to the motor, otherwise I think I'll have to take it to the shop. Any ideas?
Thanks in advance.
   / CC 1517 Battery Light #2
with engine off, voltage across batt posts s/b around 12.5 volts. With engine running full throttle, same voltage s/b >13 vollts. If not, cxharging sys is sick as you suspect. If voltage is better than 13 volts, pull yer new diehard - take it to competent shop for a LOAD test. A fair number of "new" smaller batteries are DOA...
Also make sure your start/charge circuit connections are clean to bright metal with sandpaper, etc. - including chassis ground connections and batt post connections.
   / CC 1517 Battery Light #3
Here's the troubleshooting guide from the Kohler service manual.
Thanks. As I was troubleshooting it, I found a loose connection in the ground. A little larger screw and it was fixed, thank God. Before I fixed the loose connection the voltage across the battery terminals was 11.85 vDC, afterward it read 13.58 vDC.
Thanks again for the help.
   / CC 1517 Battery Light #5
sure better than tearing apart an engine, eh? :)
Good luck with your machine.
2015 JOHN DEERE 744K-II HIGH LIFT WHEEL LOADER (A51242)
2015 JOHN DEERE...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2020 HINO 195 CAB AND CHASSIS (A51222)
2020 HINO 195 CAB...
2012 International Day Cab Truck Tractor (A50323)
2012 International...
2020 KUBOTA RTV...
2021 Chevrolet Silverado Pickup Truck (A51039)
2021 Chevrolet...
