CAV injection pump metering valve?
   / CAV injection pump metering valve? #1
2006gmcdmax
Augusta, GA
Many but mostly ford diesels or ihc or jds
I have a 69 3 cylinder 4000 diesel. Tractor runs excellent uses no oil very minor blow by from tube if any. The tractor seems to loose prime over night, but if I leave the fuel shut off pulled out it fires right up. if I push it in over night its a pain to get cranked. could my metering valve be worn? tractor has zero leaks! Also if it does loose prime I have to crank it over kill the fuel while cranking till I see no smoke gently push in on the shut off. do this three or fours times and theres a sweet spot for it to catch and crank. can't go to far forward or back buy once runing you can push all the way forward.
2022 CASE 580 SUPER N BACKHOE (A51246)
2022 CASE 580...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
2005 International 4300 Bucket Truck (A52377)
2005 International...
2016 New Holland Roll-Belt 450 Round Baler (A52384)
2016 New Holland...
19200 (A50324)
19200 (A50324)
