akjohnston
- Joined
- Jan 25, 2007
- Messages
- 29
Does any one know or have available the Caurb adjustments for a 8N ford tractor.?
akjohnston said:Does any one know or have available the Caurb adjustments for a 8N ford tractor.?
normde2001 said:there are no adjustments on those old carbs, unless you suspect the float setting has changed someway. Any mixture screws, just set 1 1/2 turns out to start and adjust for best performance, (any carb).
Soundguy said:Classic... First sentence says there are -NO- adjustments. Second sentence procedes to tell how to "adjust" the down pointing mainjet ( OUT to enrich ) and the side pointing idle air mix ( in to enrich ).. ( this assumes a MS carb like the tsx 33 / 241 variants.. etc.. )
wonderfull...
Soundguy
Soundguy said:Norm.. My point was.. you contradicted yourself in your message.. you said they can't be adjusted.. then told how to adjust... right?
Soundguy
