nikdfish
Veteran Member
I find myself in somewhat of a catch 22. We bought an 1100 lb., 18' Aluma car hauler w/ tandem 3.5K axles. We have a 2008 F-150 that came with the factory tow package, including the hitch. The F-150 hitch indicates a max of 500 lb. tongue weight & 5000 lb. towed weight unless weight distribution is added, which bumps the numbers to 900/9000. We should be able to carry up to 3900 lb. on the Aluma without exceeding the non-WD numbers and so far this has been a non-issue as we have only been transporting the 1025R FILB. We should also be OK (although closer to the non-WD max) in transporting the 3038E w/FEL & loaded rear tires & a "light" attachment like box blade or finish mower.
I got to thinking about hauling the 3038E with one of the heavier attachments like the 60" tiller, chipper or rotary cutter and figured weight distribution might be a good thing to consider to get a bit more breathing room. I did some searching to see if anyone had posted their experience with the Aluma's and WD and ran across a posting on the Aluma-KLM website "forum" where an owner asked about WD recommendations for use with an 8218 (similar to mine, but with a tilt bed). The response from the moderator was "We don't recommend that." Nothing more, no explanation. It may have to do with the aluminium construction & the architecture of the hitch assembly, but that is just guessing.
I then thought about finding an aftermarket hitch that had better numbers for non-WD towing & found several that could accomodate up to 900 lb tongue weight & 9000 lb. towed weight without WD. Sounds good, right? The only problem is that none work on an '08 F-150 with a factory hitch. Ford used different bumpers when the factory hitch is installed & the hitch is designed to function as the mount for those bumpers. Drop the hitch & the bumper goes also. The aftermarket F-150 hitches are not designed to function like the '08 factory hitches.
It is the wife's truck & she likes it so trade-in really isn't too likely.
Nick
Nick
