catwomen1
/ catwomen1 #1
catwomen1
Mt. PLeasant,SC
jcb 1400B
I have a JCB 1400B. I need to know what the lights on the dash indicate. Presently a light that looks like a lighting bolt come on when operating the machine. Is JCB and John Deere the same. I'm new and I need help.
/ catwomen1 #2
Welcome to TBN!
Is the unit putting out proper charge to the battery when running?
JCB is a separate company from Deere. Whether they build anything for each other I couldn't say. JCB is from the UK.
Info on JCB here...
/ catwomen1 #3
Welcome!
A lightning bolt is usually a universal sign for a charging problem.
Sent from my iPad using TractorByNet
/ catwomen1 #4
Agree with above posts. If the lightening bolt comes on when operating, charging system fault, as in charging system not charging or not keeping up with electrical demand.
/ catwomen1 #5
Hi. Welcome. Check for loose battery cables, low water in the battery, loose fan belt or broken wire from the alternator. If you have a load tester test the battery. Could be one or all of the above.
/ catwomen1
Thanks will check all of the suggestions. Just bough it and had not had a chancce to check it out. Currently performs well.
