yzman14
Hi i wanted to know if there are any big problems with the machine. (engine,hydralics,u/c,etc)Does this machine work well at ripping fair sized trees?Does it consume alot of fuel,and whats the gal/hr?
I'll speculate that new machines have no problems at all, and for used ones, well, that depends on their maintenance and operator's history. Personally, if you're only doing 150 acres one time, I would consider hiring it out and be done with it. A machine that size can use over 65 gal/day.Hi,i would like to know if the 345 has any major problems.(engine,hydralics,u/c)does this work well at ripping fairly large hardwoods and ripping fence lines back,because i have about 150 acres of trees to rip for farmland. does the 345 burn alot of fuel,if so whats the gal/hr.and roughly how much would a hyd thumb and a forestry package cost?
well I am fixing up and building a farm lane/road and digging a fair sized pond and digging some ditches.and is the Deere 450c lc,Deere 450lc and hitachi ex and zx450's better on fuel? if so,what is there gal/hr? (I prob will not be running at full pin either)and do they have any problems?
Just some "first glance" observations and questions for you to consider:
Those are big excavators, capable of doing a lot of work - with a competent operator. As far as "ripping" trees and digging stumps, the bigger - the better. A 345 is a beast.
Not trying to start a fight here, but you don't sound like an experienced operator. You said that you wouldn't be running the machine at full throttle. They are designed to run at full throttle.
If you've never run one of these, or have very limited experience, you might be better off to pay someone else to do it. (unless the machine is free, and will be delivered to your property at no cost?)
And, if you're going to "borrow" it for a few days, are you responsible for repairs/maintenance while you're using it?
If you are planning to purchase a machine like this, do you have any idea what it can cost to fix it if something breaks? (IIRC, the main hydraulic pump is in the $20-25K to replace) Or, how much it costs to have it moved? (A 345 is a really big machine that weighs about 50 tons. That's an oversize/overweight load, and it's expensive to pay a "heavy hauler" rig to move it.)
I think Bob's fuel consumption estimate is a little conservative. You're probably looking at closer to 100 gallons per day, maybe a little more.
