Cat 3
   / Cat 3 #1
icandoit
Flatonia,Tx, USA
1978 JD4630
I have a JD4630-150+ HP. I was wondering if there was any way I could mount a cat2 PHD on it. I was told by different people I couldn't and I could. One told me that as long as I don't go over 1000 RPM I could possibly do this. Any thoughts? How about any other implements?
Thanks in advance
Dick Austin
   / Cat 3 #2
Cat 3 refers to the 3point, which can be regular cat 3 - or it can be cat 3N, which is the same dimentions of a cat 2 with bigger holes that are easily bushed to work just fine with cat 2 stuff.
A real cat 3 3pt hitch can often be narrowed & bushed down to 2pt dimentions by shifting the linkage some - chain, bar, or rub bar.
The 1000 rpm thing is a different issue, that is a 540 vs 1000 rpm pto. Most tractors of your size allow the use of either speed, often with a replaceable stub shaft on the tractor.
It is possible a cat 2 phd would also have the option to go 540 or 1000 with a different gearset/ shaft option. I'm not really familiar with a cat 2 phd, must be heavy duty! /forums/images/graemlins/smile.gif
I would not want to use a 1000 rpm tractor with a 540 rpm phd, as you want the digger to go about as slow as possible to start with.
Would help to understand the exact issue some, you kind of mashed a couple different issues together?
--->Paul
   / Cat 3 #3
</font><font color="blue" class="small">( Cat 3 refers to the 3point, which can be regular cat 3 - or it can be cat 3N, which is the same dimentions of a cat 2 with bigger holes that are easily bushed to work just fine with cat 2 stuff.
--->Paul )</font>
Diddo.
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
2018 INTERNATIONAL LT625 (A52472)
2018 INTERNATIONAL...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
John Deere 6430 Side Arm Tractor (A51573)
John Deere 6430...
