Toplink cat 2 insted of cat 1 toplink
   / cat 2 insted of cat 1 toplink #1
Hooked_on_HP
Veteran Member
Coal City IL
Ford 1900 FWD Kubota F2100E
I keep beating the ball sockets out of my cat 1 toplink. I was thinking of using a cat 2 with bushings to cat 1. The cat 2 toplink is a lot stronger. Has anyone done this or should I just find a better cat1 toplink. The one I am using is from TSC. Also does your toplink stay with the tractor or with the attachment.
   / cat 2 insted of cat 1 toplink #2
I have always used a cat2 toplink. I have seen very few, in my opinion, "heavy duty" cat1 toplinks.
And my toplink tends to stay w/ the tractor. At least until I hook up the PHD.
   / cat 2 insted of cat 1 toplink #3
Doesn't make any difference, those "forged toplinks" made in India suck - don't make any difference what category you buy. I thought the same thing, only to find the last inch of threads on the implement end bent after only a few days of work. I discovered there are toplinks and there are HD toplinks - some sold as OEM toplinks. But be prepared to pay. You can get one good one for $60 plus, or get three cheap throwaways for the same sixty bucks.
I went another direction, and got a Cat 2 hydraulic toplink with a 1.125 inch rod. Tough bugger, I've already beat it harder and longer than any previous manual toplink, and it just asks for more.
//greg//
   / cat 2 insted of cat 1 toplink #4
The OEM NH cat 1 link I got with my ex-NH 1920 was ver HD.. It went with the tractor, and now for cat 1 stuff I use a tsc link.. never had any problems.
I've also got a couple HD cat 2 links..a nd use bushing to cat 1 on some equipment.
I've got a real old 2 piece ford toplink.. it's 2 bars that slide apart and use bolts along their length to fasten together... If using hardened bolts.. they are probably as strong as you can get on a cat 1 toplink.. and still have it adjustable..
Soundguy
   / cat 2 insted of cat 1 toplink #5
I used bushings to match up the hole and pin size. Since mine was an odball diameter, I actually bored out one of those bushings on the lathe...they are super hardened!
   / cat 2 insted of cat 1 toplink #6
I have hydro Cat II top link, I do not use a bushing. Makes it easier to get my pin in the link.
   / cat 2 insted of cat 1 toplink #7
It's your equipment, but that also makes for an egg-shaped pin hole. Won't be long before an actual Cat2 won't fit through that hole any more. My own Cat2 HTL was far too expensive to abuse it like that.
//greg//
   / cat 2 insted of cat 1 toplink #8
Since the KAMA 22mm is so close to 7/8", you can cut bushings from 3/4" (ID) copper water pipe. As long as you deburr and reround the cut ends, they fit right over a Cat 1 pin, and are much less work than trying to overbore a hardened bushing. Cheaper too.
//greg//
   / cat 2 insted of cat 1 toplink #9
//greg//
Greg, Ha ha, now you tell me ... Agreed though.
Fortunaley, I used c-6 carbide tooling and got them to fit perfectly over a Ø3/4" pin. IMO they will last a lot longer as I can see the copper swedging over time. But then again I'm sure you made a couple of spares for that exact reason, if not, it sounds easy to do.
I machine a lot of hardened steels after heat treat, but those little buggar bushing are harder than heck! I just feel a lot better about having my pins and bushings be a good slip fit to reduce oblonging or breaking them, like you said.
   / cat 2 insted of cat 1 toplink #10
I've done the carbide bit trick too.. and it's no fun setting there oiling and waiting and oiling and waiting..
Soundguy
2011 Chevrolet Traverse 1LT SUV (A53424)
2011 Chevrolet...
Heil 28Yd Side Loader Garbage Truck (A55852)
Heil 28Yd Side...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
2013 KENWORTH T800 FLATTOP SLEEPER (A55745)
2013 KENWORTH T800...
