Cat 1??
   / Cat 1?? #1
parksfamilyranch
Farm Pro 2420 2wd
Sorry this is probably a dumb question but is a Farmpro 2420 a cat one or cat 2. I'm hunting for a quick disconnect for the 3 point because I move a lot of trailers around.
Also is the a front loader that can be purchased. I dont need anything special, just a small bucket.
Thanks in advance
   / Cat 1?? #2
Cat 1.......
   / Cat 1?? #4
Your tractor is definitely category 1 three point hitch. I suspect you need some kind of implement to adapt it for moving trailers. You can purchase a front loader for your tractor but they're not cheap, I'm guessing $4000 to $5000. I like Koyker but I believe Woods makes them as well.
   / Cat 1?? #5
The tractor's three point hitch system is a category one (Cat-1). Category one is defined by lift and top link pin size, and bottom pin spacing, but I'm sure you already knew that.
Not sure what that statement means, but you have several options to choose from. If you choose the quick hitch then you will also have to purchase a trailer hitch adapter for it, like one of these: Trailer Moving | Titan Attachments™ | Titan Attachments which you can use without the quick hitch.
Search Ebay and Craigslist. Expect to pay up to $5,000 for new, and up to $3,000 for used. Give Tommy a call at Ranch Hand Supply. Do you have the resources to install a front end loader?
123456789
2012 Ford Escape XLS SUV (A51694)
2012 Ford Escape...
2021 JOHN DEERE 1725 CCS LOT IDENTIFIER 29 (A53084)
2021 JOHN DEERE...
Ford 345C Tractor with Loader (A51573)
Ford 345C Tractor...
JOHN DEERE LOT IDENTIFIER 69 (A53084)
JOHN DEERE LOT...
2024 Greatbear Forklift Jib (A51573)
2024 Greatbear...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
