Quick Hitches CAT 1 vs CAT 2 Quick Hitch
   / CAT 1 vs CAT 2 Quick Hitch #1
HTBrooks
Navasota, Texas
Kubota L5240 HST
I have a cat 1 quick hitch with adjustable hook. I have 3 CAT 1 implements and 3 CAT 2 implements. Will the CAT 2 work with the CAT 1 implements and what about the hook? The CAT 2 doesn't adjust...How would that work?
   / CAT 1 vs CAT 2 Quick Hitch #2
The standard vertical distance between the upper and lower hooks for cat 1 & cat 2 is the same, so no problem there. (As long as your implements are QH compatible.)The width between cat 1 & 2 hooks is different with the cat 2 being obviously wider.
I have a cat 2 QH and I converted my cat 1 implements to fit on my cat 2 hitch by using longer pins I purchased from TSC, along with the QH bushing.
I only have 1 implement - my 6' shredder, that I have to adjust the hook for. Do you know if the make a top link extension to make implements QH compatible?
2006 GENIE GTH6622 TELESCOPIC FORKLIFT (A51242)
2006 GENIE GTH6622...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A48082)
2019 Club Car...
Handlair 555 Grain Vac (A50514)
Handlair 555 Grain...
2015 F-550 Bucket Truck Gas Engine (A52128)
2015 F-550 Bucket...
Hays LT1 Tender (A52128)
Hays LT1 Tender...
2015 F-550 Bucket Truck. (A52128)
