ch47dpilot
Can anyone tell me why my CAT 1 attachments lower link points are different dimensions. I have a King Kutter 5' rotary cutter, 6' finish mower and 6' Blade. Also have a 5' box blade and 6' yard rake from other companies. The inside pin dimensions vary from approximately 24" to as much as 27". For my Rotary cutter I actually had to put the pins on the inside of the lift arms or they would have been closer to 29" apart. This isn't a big issue, I have the TSC version of the Pat's easy change system, but I don't see how a quick hitch would work for everything I own. What are the correct dimensions for pin to pin on a CAT 1 (research looks like 26-27") and has anyone else ran into this problem? If so how did you fix it, longer lift pins??.
