Castrol Syntec in Kholer command 16hp?
   / Castrol Syntec in Kholer command 16hp? #1
joseph39421
Collins, Mississippi
I bought a new Cub Cadet, it has 24 hrs on it and I am thinking about useing Castrol Sytech in it. The manual on the Kholer engine says to use 10w30, will the synthetic oil be ok for this engine?
   / Castrol Syntec in Kholer command 16hp? #2
I use nothing but synthetic oil in all my air cooled engines.
30w in my 16hp generator
10w30 in my 20hp kholer lawn tractor, 7.5hp pressure washer,5hp lawn mower.
I used to have a lifter noise (tick) on a cold morning start up on my 20hp kholer tractor. After talking to a few small engine techs they said this was normal of a Kohler motor when mounted in a horizontal position like in a lawn tractor. They said the lifters bleed down so at startup they’re a little dry of oil. When I switched to synthetic oil problem solved.
   / Castrol Syntec in Kholer command 16hp? #3
I would think it would be really good for this type engine. My only concern is that it might need a little more break in time before changing.
John M
Thanks for the responses, I was wondering about the break in period also. How many hrs do you guys think would be enough? One other question, I use gunk engine flush in my car and truck engines prior to oil change, we have a ford escort with 300 thousnd miles on it and I asways flushed it. When we had to put a new head gasket on it the machanic told me that he had never seen the inside of a engine so clean, he said it looks like it only had 10 thousand miles on it, compressin is still great he said. Would it hurt to add a little engine flush to my Kholer command prior to oil change in it?
   / Castrol Syntec in Kholer command 16hp? #5
I wanted till my first oil change to switch. As far as the engine flush I couldn’t tell you because I have never used it before. Do I think it might be a little over kill, maybe but I can’t argue that point? would it hurt anything, no. But I will say it’s all about peace of mind and you have had good luck with it. So it’s up to you.
   / Castrol Syntec in Kholer command 16hp? #6
</font><font color="blue" class="small">( I bought a new Cub Cadet, it has 24 hrs on it and I am thinking about useing Castrol Sytech in it. The manual on the Kholer engine says to use 10w30, will the synthetic oil be ok for this engine? )</font>
You may want to wait until the break-in period has been reached before switching to a fully synthetic oil or you might notice a blue puff of smoke when you first crank the engine.
I have a 27 hp Kohler Pro and after the first 50 hours switched to Mobil-1 10W30 Synthetic and installed a Mobile-1 Oil Filter. 150 hours and no problems so far. I also installed an oil cooler to help with the heat. It's supposed to lower the oil temp by 40 degrees.
   / Castrol Syntec in Kholer command 16hp? #7
CarlGlas, were did you purchase the oil cooler? Was it a universal kit? Also do you have a picture of it. I was thinking of adding one to my generator.
1994 LUFKIN (A50854)
2006 Ford F-550 4x4 Flatbed Pickup Truck (A50323)
2006 Ford F-550...
2011 NEW HOLLAND W130B WHEEL LOADER (A50854)
2011 NEW HOLLAND...
2012 MAGNUM TRAILER (A50854)
2012 MAGNUM...
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
