Castrol GTX ok for NH 35D?
   / Castrol GTX ok for NH 35D? #1
jlong
Bronze Member
West Virginia
NH TC35D
I have been using Castrol GTX 10w30 in my NH TC 35D. I have been told be a NH rep to use only NH oil. I change oil and NH filter every 50 hours. I am wondering if there is more than just a price difference in the oil. If there is a significant difference, is there something available from the autoparts store, as my NH dealer is about an hour away. Thanks ahead of time for any response.
   / Castrol GTX ok for NH 35D? #2
You can use any oil that's diesel rated and of the right viscosity for the temps in your area.
   / Castrol GTX ok for NH 35D? #3
I don't think GTX is rated for a diesel. THat would be a c? rating. Look on your container and it will tell you for sure.
GregH
   / Castrol GTX ok for NH 35D? #4
Jim, you do not have to use a NH oil. But as others say, it must be rated CD or CF, or whatever NH says in the manual. I think the GTX is rated something like SJ which means it's only certified for use in non-diesel engines. Many say the S stands for spark ignition and the C for compression. Not sure if this is exactly right but it's a great way to remember it. I switched to synthetic and syn-blends years ago because they carry the diesel certification for the mulitgrade oil. I may now make the switch to the new Shell Rotella T multigrade synthetic.
2021 Toyota Corolla LE Sedan (A53424)
2021 Toyota...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55301)
UNVERFERTH 330 8...
2008 New Holland L175 (A47477)
2008 New Holland...
GRADALL XL4100 IV MOBILE EXCAVATOR (A51406)
GRADALL XL4100 IV...
Scaffolding (A52377)
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
