CaseIH 595 fuses
   / CaseIH 595 fuses #1
choco
South Australia
Case IH 595
Hi Guys,
First time poster although I have frequently searched info from these forums, just purchased a 1994 CaseIH 595 and need to know where the fuses are located on the tractor front head lights and spot lights don't work.
   / CaseIH 595 fuses #2
I have an 85 series and the fuses are accessed by removing the battery cover and looking under the rear edge which would be at the front of the dash enclosure. Those light switches are not the best, it might be your problem.
   / CaseIH 595 fuses
Thanks for the info, if the switches are the problem would a generic switch be ok to use as long as the terminals on the back are the same?
   / CaseIH 595 fuses #4
I found a close replacement on line. It's been several years and I don't remember where I got it.
I know it wasn't expensive or I wouldn't have bought it.
   / CaseIH 595 fuses
Had the switch tested and it works ok so the problem lies elsewhere, the 2 lights on the front of the cab hazard/ indicator are working but the others don't, going to test the relay as soon as i pickup a multimeter and hopefully pin point the problem.
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
5ft Rotary Tiller (A51573)
5ft Rotary Tiller...
2017 TOYOTA TUNDRA (A52472)
2017 TOYOTA TUNDRA...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
Unused Delta Crash...
