CASE VAC,No fire at plugs
   / CASE VAC,No fire at plugs #1
Carykong
near Williamsburg ,Virginia
TC 35 New Holland and 52 Case VAC,LT25 Woodmizer logmill
My CASE VAC 1952 turns over but no apparent arc at the plugs, when plug is held in proximity to the head. I have good electricity to the positive post on the coil. Test light goes on from positive post to negative post on the coil. How do I test for current from coil to distributor? and good electricity to center cap on distributor?
   / CASE VAC,No fire at plugs #2
check the points.Set them to .020
no points---aftermarket electronic distributor
   / CASE VAC,No fire at plugs #4
Put a timing light on the coil wire, it will show if it is firing or not. Check that the button didn't fall out of the dist cap, it happens.
GS-3246 MAN LIFT (A52472)
GS-3246 MAN LIFT...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A53472)
GOODYEAR SET OF...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2010 DOOSAN G40 GENERATOR (A52472)
2010 DOOSAN G40...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
