Case JX Fault Codes (Transmission)
   / Case JX Fault Codes (Transmission) #1
2003Case
Billings, Mt
2003 Case JX90U
Good day everyone!
So I have a 2003 Case JX90U that started acting up pretty bad yesterday. The hydrostatic transmission wont engage without moving the shift lever to neutral and back to forward or reverse. There is no slippage or concerning sounds, vibrations or anything. All seems to be well... Except the turtle and rabbit lights will either flash together or from one to the other. It rarely has done this but yesterday it get bad quickly. For context I was in an very tight spot back blading between a building and retaining wall so I was in gear 1 range 1 going as slow as possible (the transmission has done it in other situations where RPMs were consistently higher, but not as bad).
I pulled fault codes for the first time ever on the tractor yesterday and found 10. I have owned the tractor for about 2 years now.
They came in this order:
1.) 11 Clutch pedal potentiometer - low voltage
2.) 47 Clutch pedal switch set too high
3.) 59 shuttle lever switch disagrees
4.) 34 wheel speed too low
5.) 13 high and low speed button pressed at same time
6.) 36 Engine RPM's too low
7.) 78 ECM Voltage too low (8V)
8.) 74 12V Supply voltage too low
9.) 23 Clutch B Solenoid - short circuit
10.) 22 Clutch A Solenoid - Short Circuit
Now I don't know when these code actually hit the computer, but the 3 I'm most worried about are fault codes 11, 22, and 23.
Does anyone have any wisdom to share? Many thanks in advance!
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
2017 Kia Sedona LX SUV (A51694)
2017 Kia Sedona LX...
1998 C6500 Chevy, 3126 Cat Engine (A52384)
1998 C6500 Chevy...
UNUSED GREAT BEAR 1.5CY SELF DUMPING HOPPER (A51248)
UNUSED GREAT BEAR...
2014 Nissan Rogue Select SUV (A51694)
2014 Nissan Rogue...
2012 CHEVROLET 3500HD SILVERADO LS DUALLY TRUCK (A51247)
2012 CHEVROLET...
