Comparison Case/Ingersoll or Deere?
   / Case/Ingersoll or Deere? #1
aczlan
Good Morning
Northern Fingerlakes region of NY, USA
Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
I have the following tractors available locally:
Case 4018 (w/48" single stage snowblower and 48" deck)- $1750 from a local Kubota/Cub Cadet dealer that I have a good relationship with
Case 4016 (w/48" single stage snowblower and 48" deck) - $1350 from CL
Deere 425 (w/47" 2 stage snowblower, 54" deck, PS and a cab) - $3900
Deere 345 (w/47" single stage snowblower, 54" deck and a cab) - $3700
Deere GX255 (w/47" single stage snowblower, 48" deck and a cab) - $4000
All have hydro transmissions and all (other then the 345 which doesn't say) have hydro deck lift.
This is for a commercial property which I am looking to upgrade from a 2005 Cub Cadet LT1050 with its SLOOOOOOOW forward speed and clog prone deck. This will probably also replace a 11/28 snowblower for clearing the sidewalks. The plan is to also be able to clear parts of the parking lot if we get a little snow (but not enough to call the plow guy).
Any suggestions?
Aaron Z
Any perks like warranty or 5 day trial run?:thumbsup:
I should be able to get a couple of day demo on the Case from the Kubtoa dealer... The others are all on CL and I dont think it would be possible.
Aaron Z
   / Case/Ingersoll or Deere? #4
These are obviously used. I'd consider the one with the best local service for parts and repairs. JD is probably easier to get local service etc. IMO
That is my thought. I would probably have any major service (bigger than changing the oil or a belt) done at the Kubota dealership as they are close and while expensive, they do good work.
Aaron Z
   / Case/Ingersoll or Deere? #6
I think I would look into the 425 on your list for $3900. Really though I would have to compare all of them to see which ones were in the best condition for the money.
The 425 is a well thought of unit and does have a two stage blower.
   / Case/Ingersoll or Deere? #7
Parts will be a lot harder to get and more expensive with the Case. I know - I have 5 of them. However, if well maintained, you won't need many parts. I would put that single stage Case 48" thrower against anything out there. They will move lots of snow. They also do a great job mowing.
However, a cab would be really nice. If I had the money I would get the 425.
   / Case/Ingersoll or Deere? #8
I have both a Cub LT1050 and the Ingersoll 4016 (with the 48" mower and blower) I use the Cub to trim around the house because it's turning radius is much better than the Ingersoll, but I switch to the Ingersoll to do the open areas as it's comfort and cut are much better. As mentioned earlier, the Ingersoll's are tanks, but their close quarters handling are not as good as some others out there. All depends on the area you are looking at using it in.
   / Case/Ingersoll or Deere? #9
I had a 4018 years ago and loved it. I had purchased it for home use- mowing about 1.5 acres at the time. I had the hydravac for the mower and it did superb! Also had the front blower (belt driven) and had no complaints.
Paid just over 10k for everything new- I think that was 1996 or 97. depending on the age and condition I think the price you listed is reasonable.
How far will the Ingersoll throw snow? How does the 16 HP engine do pushing the 48" deck and blower when you are in heavy stuff?
Aaron Z
1999 Toyota Tacoma Pickup Truck (A50323)
1999 Toyota Tacoma...
2014 Ford Taurus AWD Sedan (A50324)
2014 Ford Taurus...
JOHN DEERE/UNVERFERTH 1700/330 (A53084)
JOHN...
2015 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2015 KENWORTH T680...
2014 Kubota RTV1140 CPX (A50121)
2014 Kubota...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
