Case IH995 three point hitch wont lower under load
   / Case IH995 three point hitch wont lower under load #1
jmk121
Case IH995
Hello, I have a Case IH995 1992 model tractor and the three point hitch wont lower under load. It raises and lowers just fine with no load and there is no problem at any time raising it. If you stand on the lift arms they wont go down until you remove almost all pressure on them. It will go down in about 15 minutes with a load on it after the tractor has been turned off. I was running a flail mower and hit a stump I didnt see and that stopped the tractor so a pretty good impact and the problem started shortly after that. This tractor has draft control and the problem is the same no matter the position of any of the controls except with the draft control on full light which causes the hitch to raise as it is supposed to.
Thanks for any help!
2012 Ford F-350 Mechanics Service Truck (A51692)
2012 Ford F-350...
New/Unused Agrotk Tire Changer (A51573)
New/Unused Agrotk...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
TOYOTA 7FGCU25 LP SIT DOWN FORKLIFT (A52472)
TOYOTA 7FGCU25 LP...
