Case IH mx230 hydraulic problem
   / Case IH mx230 hydraulic problem #1
rmything
I keep getting an aux fault when i am spraying with my tractor. when this happens my hydraulics quit working. I then have to shut off the tractor and start it again.what are the probable causes for this fault.I have checked all grounds as well as all connections relating to the auxilarry control.Any help would be appreciated.
   / Case IH mx230 hydraulic problem #2
I've seen that problem too but I haven't had it shut the hydraulics down.
Normally when I get a "hitch capture" I am able to clear it out by using the lever to control the 3-point and move it as if I was raising/lowering and this has cleared the capture fault and everything worked fine.
I also get one that says "pto capture" and it goes away by hitting a button on the console on the right forward cab pillar that either says enter/reset/clear.. honestly I can't remember off hand what it says but I know it looking at it.
Nest time I'm in the 230 I'll let ya know, but it may be a while as we can't plant nothing, work any dirt and if there is a harvest it will probably be then before I am in it other than to move it maybe.
I think it is more of a computer error than a physical problem as I have got the hitch capture and pto capture since it was new and the MX285, the 8950 and I think while the farmer I work for had the 7150 it did it too.
Iam able to clear the codes whenever they appear but, when the fault happens I have to reset the tractors computer by switch the key on and off quickly to get the hydraulic that the code appeared o to work. I noticed that there is a hydralic leek under the cab.Could this be making the sensor that keeps going get too hot. I don't really know where this sensor is located, if anone knows please fill me in. This is really starting to affect how much work I can get done in a day so any info will help alot. Thanks
   / Case IH mx230 hydraulic problem #4
I don't know where the sensor is but if you have a leak and occasionally get a hyrdaulic leak that's where I'd start.
   / Case IH mx230 hydraulic problem #5
In order to tell what sensor is malfunctioning, if it is vs a failure of a part or a low pressure problem do to the leak the codes are the key. That tractor will tell virtually all and allow many adjustments from the computer system built in.
2016 John Deere 318G Skid Steer Loader (A51573)
2016 John Deere...
INOP/NON-RUNNING 2006 Mack CV713 Granite Truck, VIN # 1M2AG11C56M039887 (A51572)
INOP/NON-RUNNING...
JOHN DEERE 8245R LOT NUMBER 270 (A53084)
JOHN DEERE 8245R...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
FAKE (A52472)
FAKE (A52472)
