Case IH DX29 hydrostat adjustment
   / Case IH DX29 hydrostat adjustment #1
ms1780
Oronogo, MO
Case IH DX29
Can anyone tell me how to adjust the hydrostat on a case DX29? It creeps backwards if I don't apply slight forward pressure on the hydrostat pedal.
I got the hydro adjusted. Just in case anyone else ever needs to know. You remove the access panels on the right and left side below the dash. You have to remove the flasher and key switch from the one on the right. There is a cylinder on the right side that returns the hydro to neutral. You remove the pin on the cylinder shaft and the spring clip that holds the cylinder itself in place and remove the assembly. Then you can adjust the linkage and reinstall.
TAKEUCHI TL8R2 SKID STEER (A51242)
TAKEUCHI TL8R2...
2018 PETERBILT 579 DAY CAB (A51222)
2018 PETERBILT 579...
2011 CATERPILLAR D9T HI-TRACK CRAWLER DOZER (A51242)
2011 CATERPILLAR...
Master MGH8500IE 8,500-Watt Generator - Electric Start, 18HP Honda Engine (A51039)
Master MGH8500IE...
2013 TRAVIS BODY & TRAILER, INC. ALUMINUM BELLY DUMP (A50854)
2013 TRAVIS BODY &...
71053 (A49346)
71053 (A49346)
