Case IH DX29 attachments won't move
   / Case IH DX29 attachments won't move #1
Findoutwhy
Michigan
You name it
I have a Case IH DX29 after changing the hydraulic filter the front attachments & the 3 point hitch will not move up . Any help would be appreciated. Thank you.
   / Case IH DX29 attachments won't move #3
Welcome to TBN!
Do you have the owner's manual and/or service manual for the tractor? Each machine is a bit different, and some have a process for priming the pump after a fluid and filter change. Some don't require a priming process, but will require you to remove any air from the system (which is likely causing your problem), and some it doesn't seem to matter.
The big thing is to check the manuals, or call a dealer before you try running the machine any longer. It's possible to ruin the pump by turning it without enough fluid in it...usually a problem with larger machines, but not worth messing with just in case.
I have the owners & shop manuals .it says to check linkage, did looks fine. I did bread the air also.
I have the owners & shop manuals .it says to check linkage, did looks fine.i did bread out the air also.
Update : The case problem was that the oil pump could mut suck up the Hyd fluid from the tank .fix put about 14 psi pressure on/ in the tank to help push the oil up to the pump .prob fixed .
Thank everyone for the help.
   / Case IH DX29 attachments won't move #7
That makes sense....glad it worked out. Next time you can avoid needing to pressurize the tank with air by raising the FEL fully before changing the fluid. Obviously, you need to be careful with a raised FEL (probably block it), but after the fluid change, lowering the FEL will force fluid into the tank under pressure and reprime the pump.
Will remember to do that next time. Thanks
2016 New Holland Boomer 47 4WD Front Loader Utility Tractor with Bush Hog BH16-2 (A50322)
2016 New Holland...
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
HOPKINS 40 TRI-AXLE DATA VAN TRAILER (A50854)
HOPKINS 40...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2022 CATERPILLAR 926M WHEEL LOADER (A51242)
2022 CATERPILLAR...
Killbros 260 Seed Conveyor (A52128)
Killbros 260 Seed...
