CASE IH 8420
   / CASE IH 8420 #1
steveky
Philpot, Ky
Kubota/ L3010HST, BX 1800
Anyone had any experience with this baler. Bought one yesterday, do I need the gathering wheels? Any good sources for parts and owner manuals?
Thanks for your help
   / CASE IH 8420 #2
The Case-IH 8420 makes a 39" wide x 54" tall bale the same as its Hesston 530 twin.
The Case-IH 8430 makes a 47" wide x 51" tall bale the same as its Hesston 540 twin.
My experience is with the Hesston 540 and that did a good job of picking up the double windrow (18' worth) without gathering wheels but it has a little bit wider pickup. I think you will be fine if you are only baling single windrows. Just make sure you have good uniform windrows. If you want to bale double windrows I think you will need the gathering wheels. Otherwise you can make a few double windrows and try it that way you won't have to fight the entire field if the baler can't pick up the entire width of the windrow.
They are nice balers and if the gathering wheels are not very much money then add them if you want or try it first then go from there.
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
44511 (A51692)
44511 (A51692)
2015 International DuraStar 4300 26ft. Box Truck (A51692)
2015 International...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2014 FORD E-350 11 PASSENGER VAN (A52472)
2014 FORD E-350 11...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
