case ih 3394
/ case ih 3394 #1
wrenchhead
Cold Spring
case ih 3394
Hello. i am new to this forum. i have a Case IH 3394 that i did a complete powershift rebuild. i got it all back together and running. i was getting the transmission low oil pressure light coming on. i followed the repair manual and did the test. when i would dead head the pump by blocking off outlet pipe and plugging off the compensator line. i would get 80 psi at idle where spec was 200 psi. i hooked up a flow meter and the pump lost all pressure after roughly 15 seconds. we took pump in to get rebuilt. installed rebuilt pump. i started tractor and now while i am cranking the tractor i the 350 psi, but when the tractor starts i loose all pressure, when i
shut the tractor off. the pressure reading jumps up to 350 and drops to zero again. tried to bleed pump. but not sure what else to try!
/ case ih 3394 #2
I can't help you any to fix your problem but as you said new here ,it will be nothing short of a miracle if there is a Case technician on this forum to help ,you need to search a forum that is geared toward Case .Yesterdays Tractors would be a start they have lots of Case .There are likely more but I have no suggestions. You have a tractor that is neither new or old. Good Luck .
http://www.mytractorforum.com/36-case/
This may also help
2008 Volkswagen Eos Convertible (A61574)
2008 Volkswagen...
2018 Lincoln MKT Town Car AWD SUV (A61574)
2018 Lincoln MKT...
2009 Toyota Camry Hybrid Sedan (A61574)
2009 Toyota Camry...
KUBOTA 72" PIN ON BUCKET (A64280)
KUBOTA 72" PIN ON...
iDrive TDS-2010H...
40ft Shipping Container (A64194)
40ft Shipping...
