Snow Case IH 275 Front Snow Blade/Plow
   / Case IH 275 Front Snow Blade/Plow #1
Kurtrado
Case IH 275 - Turf Tires
With a Case IH 275 31 hp 4WD Compact Tractor, there is a rear mounted hydraulic valve that can be routed to the front of the tractor to support a hydraulic blade/plow. I was wondering if anyone knows of any plows or blades that can be modified or are compatible with the 275 and any tips for mounting, hydraulic vs manual tilt, and problems with the setup in general.
Thanks alot for the help
SHOP MADE PROPANE TRAILER (A50854)
SHOP MADE PROPANE...
2009 Ford F-250 Pickup Truck, VIN # 1FTSX21Y49EA41686 (A48836)
2009 Ford F-250...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A51222)
2016 VOLVO VNL300...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
