Case IH 275 Blade/Plow
   / Case IH 275 Blade/Plow #1
Kurtrado
Case IH 275 - Turf Tires
With a Case IH 275 31 hp 4WD Compact Tractor, there is a rear mounted hydraulic valve that can be routed to the front of the tractor to support a hydraulic blade/plow. I was wondering if anyone knows of any plows or blades that can be modified or are compatible with the 275 and any tips for mounting, hydraulic vs manual tilt, and problems with the setup in general.
   / Case IH 275 Blade/Plow #2
There are some examples in Customization, and more in the Snow Removal section, of various ways guys have installed plows on the tractors. Many have hooked up the angle cylinders (I assume that's what you meant when you said "tilt") and some haven't.
I believe some have connected their rear hydraulic outlet for the angle, which seems to be what you want to do.
Almost any blade can be modified to be compatible with almost any tractor.
Good luck!
2019 Kubota F3990 72in Commercial Mower (A50322)
2019 Kubota F3990...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A52748)
Koyker Loader...
2017 Nissan Sentra Sedan (A50324)
2017 Nissan Sentra...
International 284 Tractor (RUNS) (A50774)
International 284...
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
City of Lakeland (A51691)
City of Lakeland...
