Case IH 235 Hydro drive issues
   / Case IH 235 Hydro drive issues #1
Purchy
Gerang Gerung, Victoria, Australia
Case IH 235
Hi all, new to this forum, but hoping someone can help or at least me point me in the right direction. I have a little 18hp Case IH 235 and the hydro transmission is terrible. I have done a full oil and filter change, and it still has no 'get up and go'. I struggle to the most basic of tasks with it, and constantly have to gently 'ride' the hydro shift to get it to move. Any suggestions on what I can do or what I should check?
   / Case IH 235 Hydro drive issues #2
Welcome, I have a 234 it’s the same tractor, first of all did you try running it in both speed ranges ? Does the hydro pump make a lot of noise (whining) when you increase speed control lever? There’s a lot of different things that can be wrong from the clutch slipping to a speed control linkage roll pin broken. Has this condition existed for a while or did it happen all at once? I’ve never encountered the problem you’re having so a little more info is needed.
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2013 Ford Edge SEL SUV (A51694)
2013 Ford Edge SEL...
2025 New/Unused Wolverine Ripper (A51573)
2025 New/Unused...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
