Case IH 1120 CUT hydro charge pump help
/ Case IH 1120 CUT hydro charge pump help #1
Graderpete
Chatham-Kent, ON
Mahindra 2216HST
Hello all,
I've just finished installing a new hydrostatic charge pump on my 1120 case ih and i'm still not able to get the machine moving. Found the internal gear in the charge pump that runs off the main driveshaft was in 2 pieces when i split the tractor, so ordered the new pump and installed.
When putting it together i did my best to put as much oil as i could keep from leaking out, into all the internal parts. Now I've got it all put back together and i'm not getting much response. I've cracked every line I could find to get the air out and tried putting a little air pressure on the hyd reservoir to push some oil into the tougher spots.
I'm assuming there must still be air somewhere in the system, not very knowledgable on this though.
Any help/suggestions are appreciated.
TIA
*also, this tractor is the twin to Mahindra 2216 HST and Cub Cadet 7205
429858 (A61165)
429858 (A61165)
StarFire 3000 Receiver (A63116)
StarFire 3000...
2009 TROXELL KILL TRAILER (A63569)
2009 TROXELL KILL...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2018 New Holland C227 Compact Track Loader (A63118)
2018 New Holland...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
