CASE G 320 C
   / CASE G 320 C #1
zigzag
Hope I'm in the right spot.What I have is a new job,I need to know the firing order,and maybe just what it is I'm working on.So heres what I have.A Case Crawler G 320 C 3000402 All I know about the motor is that it's a 4cyl,gas.Any help would be GREAT.
   / CASE G 320 C #2
Zigzag, I'd say you're in the right spot for this topic, and I'd generally discourage duplicate posts, but in this case (no pun intended), it might be a good idea to post this message in the "Construction Equipment" forum also. Sorry I can't help you, but I figure there's a good chance some of our members can, if they happen to read your message.
   / CASE G 320 C #3
If you have the valve cover off, on a 4cyl, each 180 or half turn one valve should open on each cyl.
Bring it up on compression on no1, rotate 180 and the exhaust will start to open, bring it up, and the next cyl that opens an exhaust will be two and so on. Is best to have a manual, but this will work. Also keep an eye on the distributor so you know the rotation when connecting wires.
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
20711 (A50323)
20711 (A50323)
2020 CATERPILLAR 299D3 XE SKID STEER (A52705)
2020 CATERPILLAR...
2022 BOBCAT S64 COMPACT SKID STEER LOADER (A53473)
2022 BOBCAT S64...
2016 Freightliner TMA (A52377)
2016 Freightliner...
