Case Farmall 75
   / Case Farmall 75 #1
rwendel
*********, TX
Case 75C Farmall, Ford 2120, Ford 4000, Ford 8000, Kubota BX1800, Farmall 140
I’m having an annoying issue with my cab Farmall tractor while using it. Without any known reason, the parking brake light starts blinking and a buzzer starts buzzing. It only lasts a few seconds and then will repeat several times. It’s sporadic when it happens and I can’t recreate it. I thought maybe a seat switch, any thoughts were to starts?
Also sometimes the parking light keeps blinking for a long time without the buzzer.
   / Case Farmall 75 #2
Does applying and resetting the parking brake fix it temporarily?
Was your tractor one of the Farmalls made by LS in Korea?
   / Case Farmall 75
I haven’t tried to shift it into the parking gear but I will. My tractor is a 2014 model, I was told when I bought it at an auction some years back. It’s a 75C
   / Case Farmall 75 #4
75C is built in Italy. 2014 got an engine change - just for reference - not likely your problem. I’ve had somewhat similar problems with parking brake switch adjustment on different brand equipment.
   / Case Farmall 75
Thanks for your info
2019 MDB FM180 FINISHING MOWER (A51247)
2019 MDB FM180...
Year: 2005 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 Door C... (A54814)
Year: 2005 Make...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
1721 (A54756)
1721 (A54756)
