Case 895xl problem with F/R shift
   / Case 895xl problem with F/R shift #1
grzybulec6666
Case Ih 895 xl
Hi all! I bought case ih 895 xl few weeks ago and I have a problem. Everytime when I stop engine, the tractor starts rolling like without engaged gear. The gearbox is equipped with hydraulic F/R shift. Hydraulic fluid is just between min and max and there is not a problem with driving whilst engine is running. I have heard that the hydraulic fluid has to be filled up to 3 cm above maximum, but before that i want to hear from you any opinions about that issue. Did someone of you have the same problem ?
best regards from Poland
   / Case 895xl problem with F/R shift #2
I have an 895 and I have tested this on a slight incline. Yes, the tractor will roll until the "drag" of the transmission stops it---or doesn't stop it. In short, I suspect there is nothing wrong with the tractor. You cannot depend on the transmission to prevent the tractor from rolling when the engine is stopped (even in gear)--it's just not safe. The operator manual tells us to place all controls in neutral and apply the parking brake before shutting off the engine. This is what I do. My hydraulic fluid is in the normal full range and the tractor operates fine (knock wood). Hope this helps.
2015 JOHN DEERE 744K-II HIGH LIFT WHEEL LOADER (A51242)
2015 JOHN DEERE...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2013 MACK ELITE...
Land Honor Portable Screener (A50514)
Land Honor...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52128)
2006 Magnolia Dry...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
