Case 830 CK Heater Hose Help
   / Case 830 CK Heater Hose Help #1
splashgtp
I have a 1968 Case 830 CK with diesel engine. I never tried the heater before I took the cab off. I just put it back on and I can't get coolant to flow. I don't know if the lines are hooked up right. The hoses and heater core are not plugged.
-1 heater is hooked up to the water pump.
-the other hose is hooked up by the thermostat
While the tractor was running, I took the hoses off but there is no flow if they are held above the coolant level.
2013 Nissan Titan Ext. Cab Pickup Truck (A51692)
2013 Nissan Titan...
A1 MIST SPRAYERS RESOURCES TX3PT LOT NUMBER 85 (A53084)
A1 MIST SPRAYERS...
Hustler Raptor SD (A51573)
Hustler Raptor SD...
Ryobi Sliding Compound Miter Saw (A51573)
Ryobi Sliding...
(1) Drum of Algicide (A51573)
(1) Drum of...
2015 ford f350 4x4 mechanic SERVICE TRUCK (A52377)
2015 ford f350 4x4...
