Hi, I have a 2001 case 75xt skid steer with over 4000 hrs. I bought it around 3000 hrs. When I purchased it the right side drive was already weak but it has slowly been getting worse. I can't seem to clearly diagnose what the problem is. I had drive motor seal kit put it. Was worse when I reinstalled. Removed again and sent to another shop. They found a small steel ball missing inside which brought it back to about the same as it was prior to seal kit. My own testing and that of different shops seems to show proper pump pressure and case drain is the same on both motors. I swapped lines to the motors and it's not clear to see if the problem follows the pump or stays with the one side. Linkages all appear fine. It drives but is soft on the right side. Corners are slow turning that way. Usually can still get tires to spin but barely.
Also, the last while the loader drifts down on its own. More so when running. Not as much when engine is off. When I go to move the lever to lift the loader arms, the loader drops instead of lifts. As I push lever further out to lift, then the loader arms lift. Is this definitely in the spool valve and not in the cylinders themselves? What do I check first?
Thanks for any help in diagnosing this.
