Backhoe case 580sk
   / case 580sk #1
jbeindit
michigan
case 580sk
Hi I have a case 580 sk backhoe 1992 the forward and reverse shuttle locks into gear,it is not a linkage problem I have taken the spool valve off several times and it is in perfect shape the spring detent works as it should. A mechanic told me he thought it could be a broken spring in the shuttle that is not releasing pressure which is causing the spool to lock in gear. I was wondering if anyone knows if this is the cause? I would appreaciate any feedback. One otherthing I was wondering before it started locking in gear when I would drive down the road in 4th gear and climb a hill it would slow down without loss of rpm I thought torque converter might be getting weak? thank you jim
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A53472)
2021 NEW HOLLAND...
JOHN DEERE 17P LOT NUMBER 227 (A53084)
JOHN DEERE 17P LOT...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
Case Maxxum 140 (A50120)
Case Maxxum 140...
2012 LEDWELL & SONS ENTERPRISES, INC. 48 HYDRAULIC TAIL DROP DECK TRAILER (A52472)
2012 LEDWELL &...
