Case 580SE Hyd.Hose removal
   / Case 580SE Hyd.Hose removal #1
Dogin88
ShermansDale,PA.(Cumberland county)
87'Case 71'John Deere, 59' WD45 Alice
Any one know the easyway to changeout the control valve hose's the ones that connect on the bottom then go up-threw the boom, Like a standard 1"1/4 open end wrench just is a little crude.Maybe a Crowsfoot?
   / Case 580SE Hyd.Hose removal #2
I had that problem with my 580ck. I found a wrench I didn't care much about. Then cut it short enough to fit in the spot. I then welded a 1/2" socket on the side of the wrench. With the use of a 1/2" drive ratchet and 18-20" of extension (and several mirrors) I could get the hose of and on. It worked much better than it looked. The worst part is sacrificing a 1-1/4" wrench. Good luck
Dean
Thanks, Dean; The Case dealer near me GROFF, Mechanicsburg,PA. Wants $76.00 Just for one 1"1/4 tool made just for that job.There are more hoses but with smaller nuts.
   / Case 580SE Hyd.Hose removal #4
Yeh there was a couple sizes depending on what type of hose ends you have. I think I had a 15/16 and 1-1/4. To be honest I would tack weld a piece of steel on the wrench for the smaller sizes. Like I said its hard to sacrifice a good wrench so adapting the one already made was easier on the pocket book. I would just grind off the spots of weld when needed for the larger size again.
Good luck
Dean
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
2000 Ford Expedition SUV (A51694)
2000 Ford...
Voltage 5th Wheel Travel Trailer (A51694)
Voltage 5th Wheel...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
