Case 580SE cab parts
   / Case 580SE cab parts #1
4RIDER
Wilton,NH
CASE 580SE
Hi,
I am new owner of 1983 Case 580SE backhoe and new to TractorByNet. I am waiting on WSM I've ordered online. However I ho have case parts manual and I am looking for sources for used Case 580 parts and in particular cab parts, like side doors. It seem that these otherwise built as tanks machines have weak fenders and doors. Almost all of the machines I've looked before I bought mine have cab/cab floor/fenders rust issues. Now given the fact that these machines are in NH,ME,MA,VT (states around me) and they are cheap snow machines it is understandable they will suffer from some rust.
I want to replace one side door, top side glass on both sides and the glass one on the rear. I'm looking for used ones and hope to get some advice from more experienced Case backhoe owners on which are the good tractor salvage yards in NH.
I know that there is a big tractor salvage yards down in PA - Wengers of Myerstown, PA, but I am hoping to source some Case construction equipment parts in NH.
Thank you!
   / Case 580SE cab parts #2
I have found a lot of parts (new & used) by using the part number, through a search engine such as Google.
Thank you DJ54! Google search is always on the list.
   / Case 580SE cab parts #4
G'day IIRC the glass you want is flat we use our local windscreen guys to cut and fit laminated glass on these type of panels and it usually works out as cheap as going to a wrecker, as for the rust in the door/frames if you have a grinder and welder then it is not too hard to cut out and replace these bits as they are not structural to the rops if they are part of the swinging door.
Jon
Thank you for the warm welcome and the advices on the 580SE cab parts. Yes, after looking online here an there, it looks like the cheapest way to fix rusted cab is to go the grinder welder path. I've also contacted the local auto glass shop and have a decent quote for the missing 3 pieces of glass ($218 for LH & RH upper door glass, plus upper back glass). Way cheaper then online offers. BTW brokentractors have brand new cab door assembly for little over $2K, yup....Case Backhoe Cab Door | New, Rebuilt, and Used Machinery Parts | Broken Tractor. Almost 1/3 of what I have paid for the entire backhoe.
JOHN DEERE Z960M LOT NUMBER 102 (A53084)
JOHN DEERE Z960M...
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
2018 JOHN DEERE 160G LC EXCAVATOR (A51246)
2018 JOHN DEERE...
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
2015 DODGE RAM...
