Case 580c stabilizer arm removal
   / Case 580c stabilizer arm removal #1
Gordonloux
Buchanan, MI
Case 580c
Can anyone tell me the best way to remove the bushings holding the stabilizer ams in? Pin out, appears to be 2-3 bushing/sleeves that won't budge...
Many thanks.
   / Case 580c stabilizer arm removal #2
your talking about the out rigger for the backhoe correct? An old trick if you arne't trying to salvage the bushings is to run a bead of weld on the inside on them causing them to shrink with the weld. If the pin is still in place, you can try heating the outside up with a torch. A sledge or slide sledge would be the next bet im assuming.
Can you post up a picture to try and explain things better?
2010 NEW HOLLAND B95 BACKHOE (A50854)
2010 NEW HOLLAND...
2016 CATERPILLAR 336FL EXCAVATOR (A51242)
2016 CATERPILLAR...
2014 COTTRELL CX-09LS2 AUTO HAULER (A51222)
2014 COTTRELL...
JOHN DEERE 9650 COMBINE (A51243)
JOHN DEERE 9650...
2012 KENWORTH T800 (A50854)
2012 KENWORTH T800...
2015 Chevrolet Tahoe SUV (A49461)
2015 Chevrolet...
