Backhoe CASE 580C Shuttle pressures..????
   / CASE 580C Shuttle pressures..???? #1
bub13147
CASE 580C
I just bought a CASE 580C backhoe from 1980 and came with no reverse.
I purchased the Service manual and did pressure test on the shuttle as per procedure.
It has good pump pressure on idle and 2000RMP as per specs.
Also has good (same pressure 65 -145) idle/2000 RPM in Forward and Reverse but Forward tries to move the machine (1st. gear on the standard shift) but does not move at all.
Book procedure suggests Control valve which I took apart 2 times and everything is fine there. Solenoid for clutch cut out is disconnected but keeps the plunger in the control valve in (which should be cutout clutch inactive).
I think more on the lines that all forward clutches (friction material)is gone and it is metal to metal, but book does not even suggests that!!!
Please help from someone with real experience on this problem.
What am I doing wrong?
Thanks, Wilson
2018 CATERPILLAR 299D2 SKID STEER (A51242)
2018 CATERPILLAR...
John Deere D110 42in Riding Mower (A49461)
John Deere D110...
Bush Hog Mod. 300 - 14 3 pt Blade (A50514)
Bush Hog Mod. 300...
1980 PULLMAN DRYVAN (A50854)
1980 PULLMAN...
Crash Mobile S/A Trailer (A50324)
Crash Mobile S/A...
2014 Ford Taurus Sedan (A50324)
2014 Ford Taurus...
