case 580c loses power
   / case 580c loses power #1
shadowm77
i have a case 580 runs good you can drive it forward and backwards fel works good the bachoe works .
here`s the problem when i go into a gravel pile to get a bucket of dirt it loses power push cluch in litfs bucket of dirt fine try going foward and lifting at the same time no power won`t enen spin tires.
here`s what ive done so far.
put in new injectors
check air intake
check ehaust
checked lifters
cleaned little glass ball in return line
suposeably the reverser was rebuilt?
any ideas and thanks for any help
   / case 580c loses power #2
Depends on what gear you are in. If in anything but first, I'd say there is nothing wrong with it, if the pile of dirt is pretty tight. If the dirt is loose, try lifting & curling the bucket a little sooner, before getting too far into the pile. If it's not loose, try digging some loose, then try to load.
I love the torque converter much more on my 480C, then the clutch on the old 310B. I can feather the throttle, and ease into the pile, while lifting & curling at the same time, and not slip a tire, and still get a full bucket.
its pretty lose you have to stop any forward montion before it will lift then no problem. it loses power trying to do both at the same time
   / case 580c loses power #4
Sounds like you're crowding into the pile, faster than it has power enough to curl & lift, or too far, before starting the curl & lift. If it is a pile, and not loading out of a dirt bank. try and go at the pile at different angles, working back and forth. Leave space between cuts, take a couple cuts forming points, then work off the points. Think of it as more like shaving off the face of the pile. curl the bucket a bit first, then lift & curl all at the same time, giving the cutting edge's sharp point the ability to cut, as it raises, instead of trying to lift a flat edge upward, while trying to deadhead into a pile. Just takes some seat time, to get the timing all together. It will all come together in one fluid motion.
Other wise, you may need to feather the clutch as you enter the pile, just don't slip it a lot. And, you really don't need high rpm's do do this. 1/3 to 1/2 throttle should be plenty, if the timing is right on the bucket loading cycle, and end up with a full bucket.
2022 Club Car...
2006 International 4400 LP Truck (A49461)
2006 International...
LOOK! (A50657)
LOOK! (A50657)
2013 Hamm H11i Smooth Drum Vibratory Soil Compactor (A49346)
2013 Hamm H11i...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2008 Bobcat MT55 Mini Skid Steer Loader (A50490)
2008 Bobcat MT55...
