Case 580C Backhoe Transmission Problem
   / Case 580C Backhoe Transmission Problem #1
Shrek2
Case 580C(198?)
Hey guys, I'm shopping for a backhoe. I called about one today that isn't running at the moment. The current owner says it was parked about a year ago. He said that it wouldn't shift unless they took the top of of the transmission and moved things around to get it to go. He thought the syncros might be bad. Does anyone have any idea what is wrong. Hopefully it's an easy fix. I'm currently deployed to Iraq and I'm planning to have a friend go and get it for me. Just want to make sure I'm not biting off more than I can chew. I'm am a mechanic by trade but I've never worked on one of these. Any help would be much appreciated.
Steve
   / Case 580C Backhoe Transmission Problem #2
shreck, I would not buy that one because the tranny could be expensive and it you do it yourself well, they are heavy unlike a car tranny. On the other hand it could be just the yoke is busted that is why they have to open the top to shift. :drool:
Thanks for the reply. I actually bought the backhoe but I haven't picked it up yet since I'm out of the country at the moment. I was talking with a fellow in another thread and it sounds like it's just going to be a linkage problem. Thanks again.
Steve
   / Case 580C Backhoe Transmission Problem #4
Sorry, did not know you already bought the machine. However, the fork have also pins and this pins are small and could be busted and replacing is an easy fix. Good luck.
2009 Chevrolet Traverse LS SUV (A48082)
2009 Chevrolet...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
2015 Ford Taurus AWD Sedan (A48082)
2015 Ford Taurus...
2013 Minos-Agri 190B Disc Mower (A50860)
2013 Minos-Agri...
2006 Dodge Dakota 4x4 Crew Cab Pickup Truck (A48081)
2006 Dodge Dakota...
2008 CAT 287C (A50854)
