Case 580 SE hydraulic fluid ???
   / Case 580 SE hydraulic fluid ??? #3
I'm pretty sure Case would recommend TCH fluid. But last I checked about a year ago, it was $80.00 per 5 gal. pail.
Personally, I use TSC's premium trans/draulic fluid in my old 480C. Works for me, but use your own judgement.
   / Case 580 SE hydraulic fluid ??? #4
I agree with DJ, any good hydraulic oil will work
   / Case 580 SE hydraulic fluid ??? #6
Last summer I was wondering the same for my Case 580K that was low on fluid. But then the auto parts guy asked me a question that I couldn't answer! 'Is you tractor a shuttle shift? There are two types of hydraulic fluid, one for shuttle shifters and the other for ??? (I forget)"
Turned out that it was a shuttle shifter and I got 5 gallons of Wolfs Head tractor HT fluid and put some in.
That's when my problems started because I hadn't realized that hydraulic fluid is almost colorless and even in the bright sunlight the fluid level window looked empty. I had overfilled and had a heck of a time removing some oil.
You must use a flashlight even in the bright sunlight.
   / Case 580 SE hydraulic fluid ??? #7
The used hydraulic oil contains water and gas and other impurities, the hydraulic oil filtration machine can solve this problem, make it as new lubricating oil.
Find more on
Hydraulic Oil Filtration System - hydraulic oil purification system
Lubricating oil purification system
Transformer Oil Filtration System
http://oilfiltrationman.blog.com
   / Case 580 SE hydraulic fluid ??? #8
Find your local Exxon/Mobil dealer and get the Mobilfluid 424. It is a premium grade tractor/hydraulic fluid that meets or exceeds all of the manufacturers specs.
You can use the search function and find several threads discussing it at length.
2020 John Deere 6105E 2wd cab tractor (A44789)
2020 John Deere...
264 Gallon IBC Tank With Drain Valve (A42745)
264 Gallon IBC...
2020 PETERBILT 567 (A45046)
2020 PETERBILT 567...
1999 Volvo VN Truck, VIN # 4VA7BBJF5XN759815 (A44391)
1999 Volvo VN...
2014 Jeep Grand Cherokee SUV (A44572)
2014 Jeep Grand...
7’X20’ METAL FARM DRIVEWAY GATE (A45046)
7’X20’ METAL FARM...
