Case 580 CK Power Steering Problem
   / Case 580 CK Power Steering Problem #1
Atk406x
Indinaola
case 580 ck
I have a 1977 Case 580CK backhoe and the steering has become a real problem. Started off steering hard when there was a load in the loader bucket, especially at idle. Now it will not steer at all. The steering wheel turns hard but the wheels do not. However, if you lift the wheels with the bucket everything turns like it should. Checked the fluid in the pump and it's full. I found some information stating it might be the steering cylinders letting fluid past a seal but there are no visible leaks to speak of. I also heard there is a spring inside the power steering pump housing that gets weak and can cause a problem. I'm new to owning a backhoe however have worked as a mechanic years ago so I do have the ability to fix most things just not sure where to start with this one. I really need to find a solution as the backhoe is out in my farm field on top of a hill and needs to travel about 1/4 mile to get it back to my outbuilding where I can work on things.
Any suggestions would be greatly appreciated.
   / Case 580 CK Power Steering Problem #2
the bypass there saying is on the inside of the cylinders you will never see a leek ....try some lucus oil treatment it mite get you to the shop good luck ..i am starting the same deal with mine ..poor steering
2017 Freightliner M2 106 24FT Box Truck (A50323)
2017 Freightliner...
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
2005 Sterling Single Axle Dump (A47384)
2005 Sterling...
2007 JOHN DEERE 310SJ BACKHOE (A50458)
2007 JOHN DEERE...
2018 HINO 268 26FT BOX TRUCK (A51222)
2018 HINO 268 26FT...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
