Case 580 CK Intake Heater question
   / Case 580 CK Intake Heater question #1
Dirttracker18
Case 580 CK
Hello all!
I acquired this old 580CK in a great deal but it needed some significant work. After a number of years taking up space in my shop, Covid has allowed me time to get some much needed work done. I am so very close to starting it for the first time! It was not running when I got it.
While putting things back together I have had to use the shop manual to figure a lot out, since it was partially disassembled when I got it. It was also painted at least once with a lot of paint on parts.
Best I can tell I have all the wiring back where it belongs. However the intake heater does not seem to be coming on. I plan to trace the wiring as the solenoid still functions.
Here's the question; by looking at the manual it appears that the wire for the intake heater is hot when the ignition is in the "on" position. This would mean that the heater is on all the time. This doesn't seem right to me.
Is there anyone with enough knowledge of this unit to speak to how this "should" be set up? I was considering just putting a switch inline to control the heater for use when needed.
   / Case 580 CK Intake Heater question #2
key switch to the left for heat!-- heater is NOT on all the time! I have 2 old 1968 580 ck's and both are set up this way! Mine are the 188 diesels.
Thanks!
I actually found it somewhere online about turning the key the other way. I dropped everything and went out to the shop to check. Everything works! That took a problem off of my plate. I am literally hours of work away from starting this old girl for the first time.
   / Case 580 CK Intake Heater question #4
Ever get it going??? inquiring minds would like to know!!! lol!
2012 MACK PINNACLE (A50854)
2012 MACK PINNACLE...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
TAKEUCHI TB2150 EXCAVATOR (A51242)
TAKEUCHI TB2150...
2008 BMW 535xi AWD Sedan (A50324)
2008 BMW 535xi AWD...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
SAKAI SW502S-1 SMOOTH DBL DRUM ROLLER (A51242)
SAKAI SW502S-1...
