Case 530ck starting issue
/ Case 530ck starting issue #1
nate6
Durand, Michigan
1966 Case 530ck
I have a 1966 case 530ck backhoe I bought about 1 1/2 year ago, last week I was out at my property hoeing around, getting rid of a bunch of scrub brush everything was going fine, then it stalled out. I thought I might have run it out of gas, I checked, it still had fuel, I went to restart and got "click", I recently put a new battery in ( 2 days prior) so I thought I may have generator issues ( I didn't realize I needed to polarize the system), no big deal, jump it and move on with life, hooked it up to no avail, just "click". now I got serious, brought a tester to the property checked the battery, 12.6, good, checked it at the starter, again 12.6, pulled the starter off and bench tested, worked but not great and smelly, took the starter in and had it rebuilt, rehooked it up, brought a battery charger with me to make sure I had plenty of power, hooked it all up, at this point I even changed out the ground wire and ran it to the starter housing just to satisfy my OCD, and "click", Now for a side note, when I first got the click ( my hoe doent have a key, I have a jumper wire and a srew driver at the ignition switch) I clicked it a few times and the motor rolled over what I would say 1/4 rotation ( was relieved thinking the motor wasnt siezed), My question being, where do I go from here? I relieved tension on the fan belt thinking if the generator or waterpump was siezed this would take them out of play, but I noticed the hydralic pump is hooked up direct, I guess I want to make sure the motor does turn over, but I'm not sure how to go about it. I also forgot to note that because of my ignition switch debacle, I also tried starting at the starter, thus bypassing anything in the background
Any help on this would be greatly appreciated
2015 Ford F-250 Ext. Cab Pickup Truck (A64556)
2015 Ford F-250...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
2015 Nissan Altima SV Sedan (A59231)
2015 Nissan Altima...
2007 Mack CV713 Granite T/A Pole Truck (A62679)
2007 Mack CV713...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
2013 Hyundai Volster Coupe (A59231)
2013 Hyundai...
