case 5240 reverse/shuttle problem
   / case 5240 reverse/shuttle problem #1
onranch
case ih 5240 ,jd 2750,mf 65
reverse and sometimes all forward gears wont engage sometimes dont know where problem is or where to begin is it a solenoid,sticky valve ,electrical problem or what.When it works there is no problem.Dont have manuals or where to find scematics for hydralics or wiring .
   / case 5240 reverse/shuttle problem #2
You will need manuals and a few gauges to get to the bottom of this. There are several posibilities that it could be. Does it change with the use of the clutch petal or do you need to shut it off?
ty for reply Art.first time happened tractor was warmed up lost reverse then lost fwd gears .Fwd gears came back after much fiddling around dont know if clutching or playing with connections did it however did not turn off.Next day fired it up to try and fix and all was well until tractor got warm again then lost just reverse .loaded a trailer with hay without reverse turned off for two hours started up and had nothing and couldnt get it too go at all.tractor has sat now 2 miles from home waiting for fix will try and get manuals tday.reverse indicator light doesnt work properly when this is happening.
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
2017 Chevrolet Tahoe SUV (A51694)
2017 Chevrolet...
King Kutter TG72 Rotary Tiller Tractor Attachment (A54811)
King Kutter TG72...
