Case 485 Hydraulic Fill (Rookie Question)
   / Case 485 Hydraulic Fill (Rookie Question) #1
ChadRenfro
I put a well aimed tree thru my hydraulic fluid cooler and had to replace the cooler and now need to add fluid but for the life of me I cant see where the fill location is????? Please help....
   / Case 485 Hydraulic Fill (Rookie Question) #2
If this is a Case-IH 485 the fill point is a plug on top of the rockshaft housing behind the fuel tank. In case you don't have a manual, to check the level run the tractor for 3 minutes then check the level on the stick. it will check well over the full mark on the stick if you dont allow the pump to circulate oil to the top of the transmission.
UNUSED JCT SKID STEER QUICK ATTACH HAYSPEAR (A51244)
UNUSED JCT SKID...
Kohler 30 Generator (LOCAL TOWNSHIP) (A50774)
Kohler 30...
Tool Box (A47384)
Tool Box (A47384)
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-250...
2019 MDB FM180 FINISHING MOWER (A51243)
2019 MDB FM180...
2008 KALMER 4X2 SPOTTER TRUCK (A51243)
2008 KALMER 4X2...
